PTC Creo Student edition
BI_12885999
How long is the PTC Creo Student edition valid for students?
Thank you!
@BI_12885999 wrote:
Martin,
Thanks for your reply.
Could you tell me how long is the second option (creo11_unistudent) valid, please?
Thank you!
the license is valid for 1 year from the date of request. After 1 year, the license must be renewed, i.e. you need to request a license file for the next year.
Martin Hanák
7 REPLIES 7
  • Student Edition: One-year license available to all students.
  • Student Premium Edition: One-year license for home use. Available in bundles via our partners or individually via the PTC e-store.
  • University Edition: One-year campus-wide license of all Creo applications including Creo Elements/Direct. For teaching and non-funded research only
P.S. "Frequently Asked Questions About PTC Education's Licensing Program": https://www.ptc.com/en/blogs/cad/free-downloads-for-students-part-2-ptc-academic-licensing-explained
BI_12885999
(To:VladimirN)
Vladimir,
Thanks for your fast reply.
I got a PTC Creo student edition since February 2025.
I tried to log in a few minutes ago, but I got the message below:
Is this Student edition free?
Hello @BI_12885999,
Thank you for your question!
If you were able to solve your query, please document the solution in this topic and mark it as the accepted solution.
However, if your query is unresolved, you could also open a case using our Education Case Logger. Select the issue related to as "Licensing Error/Expired License" and create the ticket.
Once you receive a solution through the ticket, please help to document the solution in this topic and mark it as the accepted solution.
It will surely help other community users who may have a similar question.
Vivek N
Community Moderation Team
TRIAL and Student license are quite different "things".
Please read following documents.
https://apps.ptc.com/schools/references/install_creo11_schools_standard.pdf
https://apps.ptc.com/schools/references/install_creo11_unistudent_standard.pdf
Martin Hanák
Martin,
Thank you!
@BI_12885999 wrote:
Martin,
Thank you!
Martin Hanák
Thanks a lot!
