While building our current FTC robot model in Creo, we noticed quite a few missing parts! ![]()
Notably the "Inside C" bracket, "Inside L" bracket, the TETRIX Flats (64mm, 96mm, 160mm, & 288mm), and a few other things.
These parts have been around since at least last season. The KoP we downloaded from PTC is still named "Ring it Up" and I'm afraid it hasn't been updated. Any parts numbered past 739197 (eg: 739274) do NOT exist.
Does anyone have the Creo models for these parts, or know why they aren't incldued in the KoP download?
Thank you from FTC Team 5526!!
We are working with FIRST to address this, hopefully we will have an update soon.
Hello, our team has modelled two of the parts that you were looking for (the Inside C bracket and Inside L bracket).
I have posted a zip file HERE. Feel free to use these until an update is made. (Warning: Our parts may be slightly off, so do check them if it is critical!)
-Laurel Higham, Captain of Bionic Gaels FTC 5602
