Student edition Creo Parametric 8.0. Pro/Program will save the Input section but not the relations. It also is not regenerating the model.
I guess Student license does not contains ASSEMBLY module. Therefore you can use ProProgram in Part mode, only. Relations must be defined in Relations dialog box.
