I have drawing with multiple views and many dimensions in it. Now I want to check if a specific dimension from the model is already displayed. When searching for the dimension in the model (by its name *D224*), the dimension of interest is highlighted as desired. However, when performing the same search in the drawing, I get no results (although the dimension is already displayed). Am I doing something wrong or is it just impossible to search for a dimension in a drawing?
Greetings
to find model dimensions in drawing, you have to tick Include submodels option in Search Tool dialog box.
That indeed does the trick. Thanks a lot.
