Sketch projected onto a curved Surface
RoyHandley
7-Bedrock
Hi all
Just playing around with features of Creo that I haven't used before - I have created a sketch on a Datum surface and then projected it onto the surface of a cylinder
as shown:cylinder.png
So the question now is what can I do with it? It no longer behaves as a sketch and won't extrude so if anyone could enlighten me as to the possibilities I would be most grateful.
Not trying to do anything special - just trying stuff out!
‌if it's a single spline try sweeping a shape along it.  I use this technique to remove material to create door and headlight outlines on car bodies.
7 REPLIES 7
Hi Tim
Nice one! That's got me going - any more suggestions welcome!
Cheers
Roy
JohnF
(To:RoyHandley)
spring_washer.jpgHi Roy
I used it to sweep a shape to create a spring washer  I will post the part so you can play with it.  I projected the sketch onto a surface; used the projection as a trajectory and hid the surface.  Parts of the sketch referenced the other features in the model. Have fun.
Hi John
A nice idea. Look forward to the posting.
Roy
John
Is the part you posted in CREO 3? I can't open it using CREO2 which is all  I have access to here in school.
Have CREO3 at home so will try tonight if that's the case.
Roy
JohnF
(To:RoyHandley)
CREO 3 it is Roy sorry,
Thanks John - just accessed the file with CREO 3.
I like the ideas proposed by yourself and Tim - I must explore this further.
Thanks again
Roy
