Hi there.
I have been trying to install Creo software onto my laptop, which I have done previously on an old laptop that is now broken.
I have followed the instructions found at https://apps.ptc.com/schools/references/install_creo5_schools_standard.pdf word for word, but whenever I try to enter the licence key it asks me to log in, followed by an error. (Screenshot attached)
I was able to install the software by skipping the licensing, but obviously I am not able to run the software.
Any help would be much appreciated!
I have the same problem ! could you please provide us with a valid code?
Same issue (I posted too). I tried to reinstall 4.0 after 5.0 didn't work but now neither of them work 😞
Same thing for me. I will ask the support.
Update: Use BK500806ED0790-Y3M9-4RW5 as the license key and all should go well. Found it on another forum post discussing the same thing. Apparently the codes have changed but haven't been updated yet.
YEAH! Thanks 🙂
