HI All,
I used TW_Download_Java SDK.zip in Eclipse to connect to Thingworx and get /set properties from/to Things.
My question is :
Is it possibile to disable the log trace from console (like the following rows) ? How can I do?
08:46:59.324 [Client-EndpointMonitor-1] DEBUG c.t.c.c.e.m.ConnectivityMonitorTask - Entering duty cycle ON
08:46:59.324 [Client-EndpointMonitor-1] INFO c.t.c.c.e.m.ConnectivityMonitorTask - Endpoint not connected [name: EP_0, id: 0]. Attempting [re]connect...
08:46:59.324 [Client-EndpointMonitor-1] DEBUG c.t.c.c.e.ClientCommunicationEndpoint - Clearing endpoint authentication data [id: 0]
08:46:59.324 [Client-EndpointMonitor-1] INFO c.t.c.c.e.ClientCommunicationEndpoint - Needed to refill connections on client endpoint [id: 0] : [active: 0, max: 1]
08:46:59.337 [Client-EndpointMonitor-1] DEBUG i.n.util.internal.ThreadLocalRandom - -Dio.netty.initialSeedUniquifier: 0xc02387f5c754b960 (took 0 ms)
Many Thanks
BR
Dimitri
