As per my understanding the licensing of Thingworx Kepware Edge is Based on no. of tags will be used as below.
1) 0 to 100 tags
2) 101 to 750 tags
3) 751 to 1500 tags
4) unlimited tags.
but I want to known that is there any limitation of maximum no of channels define in TKE ?
Article - "Are there limits for Channel, Device or Tag for KEPServerEX / ThingWorx Kepware Server project?": https://www.ptc.com/en/support/article/CS281787
