Unable to open or access file
SJ_12358020
3-Newcomer
I am unable to open creo application it is showing as a license issue unable to figure it out
8 REPLIES 8
what version are you installing?
Please upload Parametric\bin\parametric.psf file, too.
Martin Hanák
11.0 student version
I am using 11.0 student version.
where can I find to upload Parametric\bin\parmetric.psf file?
where can I find to upload Parametric\bin\parametric.psf file?
I hope you know where Creo is installed on your computer. Please use Search functionality embedded in File Explorer to locate parametric.psf file.
Did you read following documents?
https://apps.ptc.com/schools/references/install_creo11_schools_standard.pdf
https://apps.ptc.com/schools/references/install_creo11_unistudent_standard.pdf
Martin Hanák
Yes I did. I am not able to locate the parametric.psf file. All the steps of installation were done. Yet it's not opening.
try to find parametric.exe file. It is located in Parametric\bin subdirectory. By default parametric.psf file is located in the same directory. If parametric.psf file does not exist then you skipped licensing during installation.
Just to be sure that you know how to search for a file, I added following link
https://www.google.com/search?q=windows+11+file+explorer+search+file&oq=windows+11+file+explorer+search+file
Martin Hanák
Hey
I have searched in the file explorer. I couldn't find the parametric.psf file. Maybe I have skipped the license part. So should I delete and reinstall?
@SJ_12358020 wrote:
Hey
yes. Unistall Creo and install it again from scratch.
Martin Hanák
