Dear First Windchill / Creo Parametric experienced user community,
I have added several FTC members to Windchill using the roles of "CAD Author"/"Team Members" as part of an FTC project. These users cannot access the workspace files using their logins unfortunately. I can access the files; however my role is one of project manager. Any ideas or suggestions?
-Emil
Hi Emil,
workspaces are all private. You need to "Check-In" files to the commonspace for others to access.
Users cannot see other's workspaces.
If it's another issue, let us know.
Josh
Hi Emil,
Josh
Hi Josh,
I did exactly that after not seing alternatives. It seemed illogical as I thought workspace was a common shared repository and seemed redundant work. I am sure there is a perfectly good reason why this is not the case. Thanks for such quick feedback, as I did not look forward to telling our 10 or so students to do potentially unnecessary work.
-Emil
Emil,
Josh's answer is correct. Windchill provides a common repository for everyone. It is often referred to as the "Common Space", but it is the folders within your Windchill Project. When individuals start to work with CAD files in Creo, they must all create their own Workspace. This creates a private location for them to do their own work and collaborate with others.
There are many functions in the Workspace to ensure your team members are collaborating with each other.
Hopefully you've had some time to take a look at the Windchill Practical Guide for FIRST document. It is very extensive and covers many of these topics. We'll keep trying to support you along the way until there is a ROBOTALK session on Windchill and Windchill CAD Data Management.
