https://support.ptc.com/help/mathcad/en/index.html#page/PTC_Mathcad_Help%2Fto_compile_the_cmplxsum_cust_func.html%23 Intente seguir los pasos para compilar pero me da un error de que el tipo de maquina es en conflicto con el tippo de maquin de destino de 34 y 64
2
1
C:\Windows\System32>cd C:\Program Files\PTC\Mathcad Prime 9.0.0.0\Custom Functions\cmplxsum
C:\Program Files\PTC\Mathcad Prime 9.0.0.0\Custom Functions\cmplxsum>cl /I..\ cmmplxsum.C /LD /link /out:..\cmplxsum.dll /entry:"DllEntryPoint" ..\ MCADUSER.LIB
Microsoft (R) C/C++ Optimization Compiler version 19.36.32535 for x86
(C) Microsoft Corporation. All rights reserved.
cmplxsum.C
Microsoft (R) Incremental Linker Version 14.36.32535.0
Copyright (C) Microsoft Corporation. All rights reserved.
/out:cmplxsum.dll
/dll
/implib:cmplxsum.lib
/entry:DllEntryPoint
..\MCADUSER.LIB
cmplxsum.obj
cmplxsum.obj: LNK2019 error: Unresolved external symbol _CreateUserFunction referenced in function _DllEntryPoint@12
..\MCADUSER.LIB : warning LNK4272: library machine type 'x64' conflicts with target machine type 'x86'
..\cmplxsum.dll : fatal error LNK1120: 1 unresolved external
Translated by the community team using Google translate.
I tried to follow the steps to compile but it gives me an error that the machine type conflicts with the target machine type of 34 and 64
Current version of Prime is a 64-bit application only, so you should compile to a 64-bit dll (x64) and not to a 32-bit one (x86).
The help sure should be clearer with this.
Mabe this old thread can be of help to clarify: Solved: Re: Prime 3.0 User Function - PTC Community
