Hello, i want to install creo 9 University edition for my studies.
When I entered BK120908EDUNIVERSITYED under sales number order or product code. It didn't go through and displays ERROR in red.
Same with the BK900908EDSTUDENTEDUNI code which some people of my university used.
I alredy had creo and my licence expired so i needed to install it again and i have already done it with the second sales number. But this time, it says "error" to me.
put following words into Google search and study results.
windows how to get physical address of network card
hello, i also saw that i could do that
You can contact academicsupport@ptc.com (via e-mail). You need to send them the Host ID (Mac address of the ethernet) and also the product code used. I hope they will send you valid license file.
Host ID ... this means physical address of network card
But i do not know if it is the same for creo 9 because it was the answer for creo 12,
And i do not understand where is my host ID, is it the login name for creo ?
Thank you for you answers
