solving system of equations in solvebock
  • November 24, 2023
  • 2 replies
  • 960 views
Hi
I have 2 equations that are written symbolically. and there are 2 variables : "D" & "z"
I cannot solve the equations even in solveblock . please help me . my file is attached
Thankyou
Community Moderator
December 1, 2023
Hi MG_10870768,
Thank you for your question.
I’d like to recommend to bring more details and context to your initial inquiry
It also helps to have screenshot(s) to better understand what you are trying to do in your process.
Community Moderation Team
A quite old, unanswered question which seems to have been moved just now from the PTC-Education-Forum to the Mathcad section here.
In case @MG_10870768  is still interested, here is a possible solution using the solve block:
The system seems to be very sensible with respect to the guess values. Using z:=1 it fails to find a solution, using z:=2 a different solution with a negative z-value is found.
Trying to solve the system symbolically threw an "unknown error".
Prime 9 file attached
