Digital filtering
NeedToKnow
Digital filtering
How to add a digital BPF (FIR/IIR) to the sampled data?
LucMeekes
(To:NeedToKnow)
Consult the Help system of Mathcad, I'm sure there are some nice examples.
But they may be in an e-book called 'signal processing', which should also be accessible through the 'Help' menu..
LucMeekes
(To:NeedToKnow)
Something like:
-MFra-
(To:NeedToKnow)
The front end of a real DSP must be made up of a low pass filter, for example a Butterworth LP of the fourth order, followed by the sample and hold system and then by the ADC. The sampling rate must comply with the Shannon sampling theorem (don't  take a sample rate at your leisure).
NeedToKnow
(To:NeedToKnow)
How about FIR filter?
-MFra-
(To:NeedToKnow)
LucMeekes
(To:NeedToKnow)
