What is the best way to insert a sketch made in AutoCAD into a Prime 2 worksheet?
You can insert your sketch in Mathcad Prime 2.0 only in the following image formats: "BMP, GIF, ICO, JPG, PNG, WDP, TIFF".
It seems like you can Copy/Paste other types of files such as PDF. I wonder though at the limitations of the above list and the implementation that lets you use other types. And no dxf?!
