Can someone convert this mcdx file into a Math 15 file?
Unfortunately PTC in its wisdom provided no way to convert a file from Prime to real Mathcad.
Actually they haven't even provided a way to convert from Prime to an older version of Prime.
All we could do for you is providing an RTF or an XPS export or a pdf print of the Prime file and you would have to retype it in Mathcad.
Find attached the RTF export of the file. Silly as it is this forum software won't allow the attachment of an *.rtf file, so I had to zip it.
