I have a problem with importing my MathCad results into the Excel component. I have two variables and I want their summation (one a range hhm, and the other one is a scalar hm). I can get the summation outside of the Excel component, but it's not working inside the Excel component.
Any tip is really appreciated. Thank you! Helya
Thank you very much for your help.
I changed the variable to the range in the sheet, but the graph drawing part stopped working. It is supposed to read a text file, and then draw a graph.
I also got another error in the Excel component.
I was wondering if anyone may help me with it. Thank you!
When using vectors as function arguments you may ave to use vecorization!
