PTC Mathcad Prime Roadmap (2021 update)
VladimirN
New features for consideration:
16 REPLIES 16
LucMeekes
23-Emerald I
(To:VladimirN)
Considering that these features are 'considered', I don't expect any of these Prime releases will sufficiently outperform (real) MathCad; so I'll stick with (real) MathCad 11, the one that predates Prime 11 by 20 years, if not more, because I don't expect that Prime 11 gets released before 2023...
I just keep thinking about what would have happened if PTC had spent their effort continuing on mathcad 16 instead of going towards Prime, which was a useless effort ... What a bad decision from some managers at PTC !
The idea of giving the outdated Mathcad a new, more up-to-date code base was right and necessary. Just how PTC then implemented this idea is a disaster and ultimately killed Mathcad as we knew and loved it. Admittedly - sometimes a love-hate relationship, too, but you often appreciate things most when you've lost them.
RIP Mathcad
CornelBejan
(To:Werner_E)
Well, what to do then?
We can complain as much as we want, but not much will change 🤔.
The PTC will most likely implement their development plans, it doesn't really matter what our wish is.
The solution is to give up and start with other math software? Or?
Probably some have been using Mathcad for many years...and are related to this software.
Yes, thats sure true!
Sure, of course! What else?
Absolutely correct! There is no 1:1 replacement. And finding a new software and get aquainted to it sure will not be an easy task and as I guess will turn into a heavy trial and error task.  Changes are very often painful, but they can also be liberating.
CornelBejan
(To:Werner_E)
@LucMeekes
It's hard for me to break up definitively with Mathcad for good ...
Well, what software did you decide to emigrate to?
Didn't migrate to other software. Still using MathCad 11 for day-to-day work. Use Prime (Express), primarily to help others in this forum.
Me neither. Still using MC 14 for most things, but starting to do some stuff with MatLab.
tietjee
(To:VladimirN)
Is there a schedule for the release dates?
VladimirN
(To:tietjee)
Not yet.
tietjee
(To:VladimirN)
Do you believe their schedule?
DJNewman
(To:tietjee)
Since our official public product calendar doesn't have a date for the next version of Mathcad, there's nothing to believe or disbelieve right now.
tietjee
(To:DJNewman)
PTC has never met a release date yet.  Why should this be any different?
(To:tietjee)
You are absolutely right, but I guess what DJNewman meant was, that PTC learned from this and found a clever way to never miss a published release date ever: They simply don't publish release dates for future version any more 😉
kfalkenberg
(To:VladimirN)
Ok - We got enough.
We went to Maple.  It has it's own diffculties but I don't feel like being taken for a ride by them...
Get lucky with PTC..
Klaus
@kfalkenberg wrote:
Ok - We got enough.
Standard Maple or Flow?
Stuart
Check out the latest
Mathcad Tip
"PTC Mathcad 15 / Prime 1-6 Update."
