I need help in creating a piecewise function for the black function so that it starts at the red point and ends on on black and i want to create a loop for the black function to do this every 2*pi/N degrees please help.
Hey I couldn't open.
Could you please send xps of this so I can see the entire file?
Hi
What version of Prime are you using? I have enclosed a pdf.
The only new stuff at the bottom of your file is this:
This wasn't what I was asking for.
I was asking for how to make the blue curve stop on black and make a circular pattern/array of the current blue curve.
Here's a brute force approach for what you were asking for.
Not sure if it makes any sense, though.
Worksheet in format P4 attached
2D and 3D stars
