cspline units in the plot
ebelmonte
8-Gravel
Dear all,
I would like to plot a cspline function with the proper units of measurement.
However as you can see in the attached document (the chart highlighted in yellow) it does not work.
Can you please help me?
Thank-you very much.
Best Regards.
Enrico Belmonte
without the use of a discrete variable
9 REPLIES 9
LucMeekes
(To:ebelmonte)
You use an undefined running variable z. I guess this means it has no units.
Define z as a range variable with the proper units and I guess it should work as you expect.
Dear Luc,
how can you assign the unit to a range variable?
Thank-you!
Enrico
z:=1m, 1.01m .. 2m
Thank-you Valery for the quick answer!
You welcome!
See more Study 1. Properties of working fluids, coolants and structural materials for thermal engineering calculations
LucMeekes
(To:ebelmonte)
In your case:
