The case logger is missing the latest version of Creo Parametric again. Someone should really figure out how to make this automatic instead of relying on someone remembering to manually update this each time a new release goes public. Creo 8.0.1.0 was released over a month ago.
Thank you for using the PTC Community and reporting this to us.
This should be fixed now. Date Code 8.0.1.0 has been added to the case logger as seen below -
Do let us know in case you have any further concerns about this.
Best Regards,
vnamboodheri
Best Regards,
vnamboodheri
