There is a new main entry on help.ptc.com for solutions, pointing to https://www.ptc.com/en/support/help/Solutions.
There are currently two entries: DPM and Building Blocks.
Below that, there is a section "Reference Documents", which points to "Windchill Quality Solutions". Although it contains the word "solution", it is not intended to be there. WQS has nothing to do with the solutions meant in this section.
Hi @Rocko.
This is not the first report of the problem and it seems to be a systems-related issue. However, a new case has been opened to address it.
Regards.
--Sharon
Hi Rocko,
Please also send an email to documentation@ptc.com to provide your comments about the "PTC Help Center" page.
Hi @Rocko.
Regards.
--Sharon
