The link to PTC Technical Support in the PTC FlexNet Licensing and Installation FAQ is broken.
Hi @TomU, thank you for bringing this to our attention. I will ask our web team to look into fixing it.
@SW_9634771 thanks for reporting this. We've updated the document and you should be all set. Please let me know if you have any issue accessing it.
