Hi!
I'm surprised, but from work, from home and from my mobile the page www.ptc.com is not working at all!
Does anyone discovered also the same problem?
I wish to be able to open the page ASAP
BR
Roman
It seems to be back now.
Great job! Now with satisfaction I can confirm it is working well again!
The cleaning crew unplugged the internet so they could vacuum. I plugged it back in.
Thanks you are the one who was access to plugged it back in ![]()
Good day everyone,
I am not sure what caused the page to go down, but will be looking into things today.
Best,
Toby
Yesterday I was able to open this page: www.ptc.com/liveworks, but it is no longer possible - why?
was the content shifted somewhere?
/liveworx or /liveworks?
you're right - thanks it is working as LiveWorx 2016 Keynotes and Sessions | PTC
I am working on adding the presentations and they will be uploaded soon - LiveWorx 2016 - June 6-9, 2016 - Boston
Best,
Toby
Good Morning! please enter in search on ptc.com e.g. "GD&T" and you'll see this:
Description: An unhandled exception occurred.
Exception Details: Sitecore.ContentSearch.Linq.Lucene.Exceptions.TooManyClausesException: The Lucene query that was generated contains too many clauses. The maximum number of clauses that are allowed in a query is specified in the ‘Sitecore.ContentSearch.Lucene.DefaultIndexConfiguration.config’ configuration file, in the ‘ContentSearch.LuceneQueryClauseCount’ setting. The value is currently set to ‘10000’. You should either make the search expression more specific or increase the value specified in the ‘ContentSearch.LuceneQueryClauseCount’ setting.
Source Error:
An unhandled exception was generated during the execution of the current web request. Information regarding the origin and location of the exception can be identified using the exception stack trace below. |
Stack Trace:
[TooManyClausesException: The Lucene query that was generated contains too many clauses. The maximum number of clauses that are allowed in a query is specified in the ‘Sitecore.ContentSearch.Lucene.DefaultIndexConfiguration.config’ configuration file, in the ‘ContentSearch.LuceneQueryClauseCount’ setting. The value is currently set to ‘10000’. You should either make the search expression more specific or increase the value specified in the ‘ContentSearch.LuceneQueryClauseCount’ setting.] Sitecore.ContentSearch.Linq.Lucene.Queries.SpanWildcardQuery.Rewrite(IndexReader reader) +875 Lucene.Net.Search.BooleanQuery.Rewrite(IndexReader reader) +396 Lucene.Net.Search.BooleanQuery.Rewrite(IndexReader reader) +396 Lucene.Net.Search.IndexSearcher.Rewrite(Query original) +29 Lucene.Net.Search.Query.Weight(Searcher searcher) +29 Sitecore.ContentSearch.LuceneProvider.LinqToLuceneIndex`1.ExecuteQueryAgainstLucene(LuceneQuery query) +1119 Sitecore.ContentSearch.LuceneProvider.LinqToLuceneIndex`1.Execute(LuceneQuery query) +754 PTC.Web.Applications.Helpers.SiteCoreHelpers.ExecuteMainSearch(String keyword, Int32 currentPage, Int32 pageSize) in D:\PTCWebsite\ptcwebproject\CodeLibrary\PTC.Web\PTC.Web\Applications\Helpers\SiteCoreHelpers.cs:365 PTC.Web.Controllers.SearchController.SearchResults(String keyword) in D:\PTCWebsite\ptcwebproject\CodeLibrary\PTC.Web\PTC.Web\Controllers\SearchController.cs:36 lambda_method(Closure , ControllerBase , Object[] ) +139 System.Web.Mvc.ReflectedActionDescriptor.Execute(ControllerContext controllerContext, IDictionary`2 parameters) +229 System.Web.Mvc.ControllerActionInvoker.InvokeActionMethod(ControllerContext controllerContext, ActionDescriptor actionDescriptor, IDictionary`2 parameters) +35 System.Web.Mvc.<>c__DisplayClass15.<InvokeActionMethodWithFilters>b__12() +80 System.Web.Mvc.ControllerActionInvoker.InvokeActionMethodFilter(IActionFilter filter, ActionExecutingContext preContext, Func`1 continuation) +453 System.Web.Mvc.ControllerActionInvoker.InvokeActionMethodFilter(IActionFilter filter, ActionExecutingContext preContext, Func`1 continuation) +453 System.Web.Mvc.ControllerActionInvoker.InvokeAction(ControllerContext controllerContext, String actionName) +533 |
Version Information: Microsoft .NET Framework Version:4.0.30319; ASP.NET Version:4.6.1590.0
Please inform proper responsible person - thanks!
I was trying hard to get opportunity to create new topic - but can't!
Hhow can I start new post thread?
BR, Roman
Hello Roman,
Thanks for reporting this. We also see the same within the PTC network when running a search with the same keywords.
As search without any special characters works, it looks like the "&" is not well handled by the Lucene search engine embedded in PTC.com's web platform.From brief testing, any search operators, when entered as keywords seem to generate an unhandled exception in Lucene.
I'll report this to the ptc.com web team, so that this can be corrected.
Thanks also to @TomU for bringing our attention to this thread, which highlights a gap when there are issues to report with ptc.com.
