need to find tools and their uses for my project
Nick you will need to run a "ptcflush.bat" on the license that your system has aquired. Open a command window and change the directory to "C:\Program Files\ptc\Creo 2.0\Parametric\bin". The batch file is located here.
Next follow this from PTC.
Resolution |
License Server is UP: server0l2 22-66-AA-CC-01-22ptc_d FLEXnet Publisher version: 10.8License In Use Free Version Expire Date SCN ------- ------ ---- ------- ----------- ----- CREODMA_STANDARD 1 9 33.0 None 1A123456 (user1@clientmachine2) CREODMA_STANDARD server02l 7788 101
Hope this helps!
Nick,
the only reliable method is stop/start license manager service on the server .
ALSO ... You can test license borrowing. If you borrow license, then you don't need permanent access to the license server.
Martin Hanak
Martin,
The ptcflush batch file is a reliable method. I have used it many many times over the years and never had any issues. Also, what if Nick does not have access to the license server
Buddy
