Define Piece Part
GaneshK
Define Piece Part
In NX there is a option as 'Enforce Piece Part'. By this option it will not be possible to add any other part/component so that resulting part will be only piece part, not an assembly part.
Is there any similar option/preference available in Creo?
BenLoosli
(To:GaneshK)
NX is a different architecture than Creo.
NX allows multi-body parts, Creo does not.
NX uses a single file extension (.prt), Creo uses multiple extensions (.prt, asm, .drw, etc.).
There is no need for this option in Creo.
18 years using UGII/NX, 18 years using Pro/E/Wildfire/Creo.
7 REPLIES 7
StephenW
(To:GaneshK)
No. Creo does not support multi-body parts so this concept is not valid.
GaneshK
(To:StephenW)
Hi @StephenW,
Thanks for the reply. I have attached a short NX video as a example.
StephenW
(To:GaneshK)
I won't download a video due to security issues.
Creo does not allow multiple parts in a part.
BenLoosli
(To:GaneshK)
GaneshK
(To:BenLoosli)
Hi @BenLoosli,
That clarify everything, Thank you! Smiley Happy
Can't we mark more than one reply as solution?
StephenW
(To:GaneshK)
No, you can only mark one as the solution.
I would mark Ben's as the solution since it is the most clear explanation.
GaneshK
(To:StephenW)
Thank you @StephenW!
