Fellow ProENGINEER/CREO users,
I'm having the following issue(s):
I've allready searched the entire (for as far as that is possible) PTC Knowledgebase and PTC help-files, there is however no documentation on how to even route a 4-way branch connection.
Examples/explanations that use non-spec driven piping are also of help!
If there is more information needed please let me know!
Thanks in Advance,
With Kind Regards,
Hein van den Broek
Some extra information about the fitting I used:
PORT0, PORT1, PORT2 and PORT3 coordinate systems are available. (I asume they are in the correct orientation/order)
PORT0 coordinate system has the following feature parameters:
Component has the following parameter:
These all correspond with the spec-driven piping configuration file parameters.
T-fittings (3-way branch fittings) work like a charm by the way.
Hi
I am sorry to say Spec piping does not currently support cross T's
Thanks, Jim
In non-spec-driven piping you can branch from another pipeline to the current one (e.g. with perpendicular option).
You can do the same with a third pipeline from the other side, so you will get a kind of four-way.
You can still add fittings to the branch points, but your 4-way will have to be added as a T-branch.
I am not aware of any issue with this kind of design, but I also can't say, whether there are none.
