I created sequence in Creo Illustrate with some notes & I want to show that description at every step.
I bind model property (steps) to Lable but it's showing no. of steps. How can I show that notes in studio.
Hi @Swapnil_More ,
I think you mention the description info and you meant the note page as shown on the picutre above - here I want to make it clear:
In the current functionality the info of this note will be not passed to Studio and we can not used it directly in Studio widget yet. So far I know there are an enhancement requested but it is not implmented yet or I do not have info about such implementation
When we check the pvz file -> rename it as zip file and then extract - then we can find in the sequence file *.pvi - the desired informaiton - as shown here in example:
So the *.pvi file has an xml style so you can easy extact this info using some script. So you can define form there an jason or other array which contains the information and later could be pasted in studio project and used for setting some widget properies when a step is played. Such techniques was already described in the post "Display sequence step names from Creo Illustrate"
Hello Swapnil,
Did you look to this thread ?
Do you a similar javascript function?
Best regards,
Samuel
Hi @Swapnil_More ,
