I am new to Thingworx and doing some experiments. I have subcribed a development portal of Thingworx foundation server hosted on trial (30 days) some where on the cloud. I am trying to connect this server with my Vuforia studio but when I enter the url of thingworks for experience service it says 'Failed to authorise experience server'.
url of thingworks - https://pp-1902092106pa.devportal.ptc.io
Please help.
@Vivektronics With Studio Trials you get few pre -configured entities and cannot create, modify or link other TWX entities. You will have to go for commercial version either PTC hosted or On premise ES setup to achieve your use case.
-Durgesh
@Vivektronics For working with Studio as Trial user, you should get registered and start Studio Trial using URL https://studio.vuforia.com/login
Once your Studio Trail instance is create you can then go to Studio Application -> Top right ... ( 3dots) configuration-> Portal Login -> Enter your PTC credentials used to create Studio Trail account . Refer attachment for details.
Upon successful registration your Experience Service URL will be configured which you should use to publish your Studio Projects. Please note you will not be able to use your development ThingWorx URL directly with Studio Trial.
-Durgesh
-Durgesh
@Vivektronics We understand the need and have been constantly updating system /product to me more productive.
However, with the current Studio Trial Cloud architecture & provisioning we have these restriction on usage & configuration.
-Durgesh
