(2nd try) CREO 7 dont saving last config and working_directory used II
ND_10940562
i already did a topic about this, but im still have the same problems
the path only works on the first try after i change it. But on the 2nd inicialization doesnt work anymore, i dont know what to do anymore.
maybe its something in my config
search_path_file $CREO_COMMON_FILES\ifx\parts\prolibrary\search.pro
template_new_ecadasm $PRO_DIRECTORY\templates\inlbs_ecad_asm.asm
template_boardpart $PRO_DIRECTORY\templates\inlbs_ecad_board.prt
search_path_file $CREO_COMMON_FILES\afx\parts\prolibrary\search.pro
drawing_setup_file C:\Users\Nicolas Santos\PTC CREO\Geral Caterpillar\(Loc)Start_files\Active Drawing_REV.dtl
format_setup_file C:\Users\Nicolas Santos\PTC CREO\Geral Caterpillar\Folhas\mfgtb-c.frm
mdl_tree_cfg_file C:\Users\Nicolas Santos\PTC CREO\Geral Caterpillar\(Loc)Start_files\tree.cfg
pro_font_dir C:\Users\Nicolas Santos\PTC CREO\Geral Caterpillar\(Loc)Start_files
pro_material_dir C:\Users\Nicolas Santos\PTC CREO\Geral Caterpillar\Biblioteca_elementos\Materials
pro_plot_config_dir C:\Users\Nicolas Santos\PTC CREO\Geral Caterpillar
pro_symbol_dir C:\Users\Nicolas Santos\PTC CREO\Geral Caterpillar\Símbolos
pro_format_dir C:\Users\Nicolas Santos\PTC CREO\Geral Caterpillar\Folhas
template_designasm C:\Users\Nicolas Santos\PTC CREO\Geral Caterpillar\(Loc)Start_files\start_tool_assy_new.asm.3
template_sheetmetalpart C:\Users\Nicolas Santos\PTC CREO\Geral Caterpillar\(Loc)Start_files\start_tool_new.prt.4
template_solidpart C:\Users\Nicolas Santos\PTC CREO\Geral Caterpillar\(Loc)Start_files\start_tool_new.prt.4
trail_dir C:\Users\Nicolas Santos\PTC CREO\Geral Caterpillar\(Loc)Start_files\TRAIL
system_colors_file C:\Users\Nicolas Santos\PTC CREO\Geral Caterpillar\(Loc)Start_files\syscol.scl
browser_favorite C:\Workspace\
model_detail_options_file C:\Users\Nicolas Santos\PTC CREO\Geral Caterpillar\(Loc)Start_files\Active Drawing_REV.dtl
pen_table_file C:\Users\Nicolas Santos\PTC CREO\Geral Caterpillar\(Loc)Start_files\Active Drawing_REV.dtl
start_model_dir working_directory
file_open_default_folder working_directory
!global_appearance_file C:\PTC\JactoUtils\appearance.dmt
!pro_colormap_path C:\ptc\Geral Caterpillar\(Loc)Start_files
!hole_parameter_file_path C:\PTC\JactoUtils\HoleChart
!pro_dtl_setup_dir C:\ptc\Geral Caterpillar\(Loc)Start_files
!template_drawing C:\ptc\Geral Caterpillar\(Loc)Start_files\mfgtb-c.frm.1
(the same config was used to work with jacto and now the lines i dont know how to change, i put as comentary)
What i did to make it permantly was reinstall the Creo, at least the start fold for the config  estabilized.
8 REPLIES 8
BenLoosli
(To:ND_10940562)
Is your system admin setting the working directory in the system config.pro or config.sys?
Open Creo, File-options and then Configuration Editor.
Look at the system loaded config.pro and config.sup files.
ACTUALLY i already lost the original config.pro of creo, because i put other config in the common files of creo.
when i open, i see this:
BenLoosli
(To:ND_10940562)
What is in that config.pro file?
it has the config i used to work daily, like the one i send before.  i was tired of seting a new place for the config, them i decide to put my config there.
What i just did, it was reinstall the creo 7
now the config is coming alright, but other problem persists
Thats is the working_directory folder not saving. For what i recall when i select one fold as working_directory, once i close and open the creo, he open in the working_directory i select before, right?
thats not happeing
i already tried file open defalut folder
As default, as working_directory and as in session
after i close and open, it open in the folder chose to be the folder with config.
Dale_Rosema
(To:ND_10940562)
Did you happen to make a backup of your config.pro?
Before I ever make changes I typically save a copy to YYYYMMDDconfig.pro so I have something to fall back on.
If not, can your IT retrieve your older config.pro from their backups?
I think you are expecting Creo to remember the last directory you were working in, that is NOT your "Start In" directory, and automatically go there the next time you open Creo?
Creo doesn't do this. It starts up with the working directory set to the Start In specified in the shortcut you use to start the program.
BenLoosli
(To:KenFarley)
One option if you want to launch Creo from different folders is to put a shortcut to Creo in each folder and then launch it from there. I think this will set your working directory to that folder.
Also, if you double click a file in a Windows folder to open it, that will also make that folder your working directory.
I use Windchill so those tricks are going back a ways since we last used folders for Creo parts.
