Community Tip - Did you get called away in the middle of writing a post? Don't worry you can find your unfinished post later in the Drafts section of your profile page.
X
I am using Creo Parametric Release 6.0 and Datecode6.0.4.0
Arial WGL is offsetting the limit tolerance. Is there anyway to align the upper + and lower - tolerance? Also the mu symbol in the micrometer is not displaying when convert to PDF. Please help.
