Assembing interface to interface (placing to receiving)
bmikulka
I'm attempting to update the standard fasteners within my company library with interfaces. However, there are some that just won't see to work - does anyone know if there's a limit to how large their family tables can be? I've triple checked that they are correctly defined as placing and receiving.
I am placing the same "placing" definition in them as in all the others, but when I attempt to assemble them into an assembly, their interface-to-interface fails to work... even though very similar models (some might have even been created using an instance and saving off) are working just fine. And although I also have receiving interfaces defined, other components fail to recognize them in the next higher assemlby as well (even if they recognize other ones).
Any ideas??
0 REPLIES 0
