Assembly X-Section does not show in drawing
agaribay
3-Newcomer
Topic: Assembly X-Section does not show in drawing.
I've done this a 1,000 times and so I'm not sure why the cross-section I
created does not appear in my drawing.
* Section - Full - Arrow Display, Model EdgeVisibility: Total.
* When I hover my mouse over the component, the cross-section
appears.
* All components show as restored (not Excl) under MOD XHATCH.
* I do know of "Interference" issues, but I don't think this
applies.
WF2
Any ideas?
-Art
Yes this is my Section view:
When I hover my mouse over same view
This message (including any attachments) contains
confidential and/or proprietary information intended
only for the addressee. Any unauthorized disclosure,
copying, distribution or reliance on the contents of this
information is strictly prohibited and may constitute a violation
of law. If you are not the intended recipient, please notify the
sender immediately by responding to this e-mail, and delete the
message from your system. If you have any questions about this
e-mail please notify the sender immediately.
agaribay
3-Newcomer
(To:agaribay)
Thanks to Richard for what worked for me (see answer below).
Thanks again guys!
-Art
I've occasionally seen this happen as well. It is not necessarily an
interference issue, but I would guess that there is some odd tangency
issue or something that your section cuts through that will not allow the
section to be created. Helical components and bent tubing sometimes cause
the problem for me. As a work around, you can move the section .001/.002
off center or create an offset section that just cuts through the geometry
that you need to section.
Changing the accuracy of the assembly will sometimes also help.
Bob Frindt
Sr. Designer
Parker Hannifin Corporation
Parker Aerospace
Gas Turbine Fuel Systems Division
9200 Tyler Boulevard
Mentor, OH 44060 USA
direct (440) 954-8159
