I want to make a copy of a cable, including the drawing, flat pattern, manufacturing models, the upper level assembly and its drawing.
What is the best way to do this without PDM of any kind?
I have tried backing up from the server to a local directory and renaming after I get everything in session, but for some reason there is a dependency to the former dash number. The really weird thing is, it will bring in the old dash number from the server when running a config.pro with no search paths.
I also tried to do a "save-as" at the assembly level and that copies the drawings but not the cable flat pattern and manufacturing models.
I am trying to avoid having to re-do the flat pattern.
