Hello,everybody!(sorry for my bad english) I am worked 7 years in ProE2001 made model mold form and CNC programm for mill.In this week my plant got a new PC with ProE WF 5.0.I have problem to get G-code format.I choose good G-POST UNCX01.f19 for example,but receive this ***NOTICE*** Using postprocessor defaults !!! .Can somebody help me to show what wrong?What I need to change? May be I can't make cnc programm with this configuration WF?
No answer or my question not understandable?
I think most of the posters here are (GMT -5)
looks like you might need to set your gpostpp_dir to the folder containing your post files it is set at default now.
You might also need to set the ncpost_type to gpost or ncpost.
I made a folder with post files,changed way gpostpp,but nothing happend.May be configuration is not full?Which companent is miss?
Have you tried doing a brand new postprocesor??
It's not so difficult
I found the problem.My license is not full and Pro\NC is "NC lite".I can create only CL code. I make ncl file in WF and after G code in old version ProE2001 .In menu manager: CL data-Post process.....input my ncl file.
