CREO 3.0 Parametric Student download
ptc-6852296
I can not seem to open CREO on my computer. I have downloaded it and followed all the instructions, but when I click on the icon's, nothing happens. I triple checked to make sure my operating system is compatable, and everything checks out. Same if I go to the Start Menu and try to open the software. NOTHING HAPPENS... Please help!
i think its a graphic issue....you might have change a setting in config.pro
graphics win32_gdi, add this at the end in config.pro
if this opens creo..then surely its the graphic drivers.
open config.pro with notepad.
Jonathan,
ask Academic support via email -
Martin Hanak
Martin Hanák
Johnathan,
Check:
1. xtop.exe is available under <Installation location>\Creo 3.0\<datecode>\Common Files\x86e_win64\obj. If xtop.exe is not available, try reinstallation after disabling firewall and anti-virus application.
2. Try to launch program by executing parametric.exe or parametric.bat available under <Installation location>\Creo 3.0\<datecode>\Parametric\bin
