CREO Text Size / Resolution Issue
WS_10638778
2-Guest
I had finished installing CREO on my computer, and this is how it looks like. It seems like the font size is too large, but I don't know how to fix this.
It has to due to high resolution laptop screens and monitors. Try MartinHanak suggestion as well as the following setting. We had to do the following at Raytheon.
Solution/Workaround:
1.From Creo set the config.pro option, windows_browser_type to “chromium_browser
2.Navigate to Creo load point;  this is our Creo 5 location. C:\Program Files\PTC\Creo 5.0.5.0\Parametric\bin, right click on “Parametric.exe”, Properties
3.From the Properties Compatibility tab, select Change high DPI settings
4.Check the box Override High DPI scaling behavior and set to “System”
Dale_Rosema
(To:WS_10638778)
Creo Parametric 8.0.7.0 on a work Lockheed Martin computer with windows 10.
Dale_Rosema
(To:WS_10638778)
See this link for Creo 8.0
https://www.ptc.com/support/-/media/support/refdocs/Creo_Parametric/8,-d-,0/creo8_hardware_notes.pdf?sc_lang=en
I don't see Lockheed Martin on the list.
check Scale setting.
Martin Hanák
