CREO4 and WINDOWS 7
Luca_Carraro
CREO4 and WINDOWS 7
I have intall Creo4 M040 on Windows 7 but not working correctly when I change the windows.
For activate another one I must select it on a bottom bar of S.O.
There are any solution for to correct it.
Thanks for your time, a greeting, Luca.
6 REPLIES 6
@Luca_Carraro
You may try newer datecode of Creo 4.0
Hi Mahesh,
unfortunately I have to work with another company that has version 40.
Creo 4 m040 is very old, the latest is M110 or M120.
There should not be any compatibility related issue with latest datecode of Creo 4.0
What build of Creo 4 are you installing?
Do you have SP1 on Windows 7 with the latest patches?
Windows versions supported from PTC software matrix charts:
Windows 7 Professional 64-Edition
Windows 7 Ultimate 64-Edition
Windows 7 Enterprise 64-Edition
 Creo 4.0 M010 and later requires all required Microsoft updates to be installed on Windows 7 and 8.1.
Hi Ben
many thanks for your attention.
I have intalled Creo4 M040.
In attachment my version window 7.
About update there is  some one in particular to check?
Thanks for your time, regards Luca.
