Removing GD&T advisor from parts
djacobsma
6-Contributor
Does anyone know how to remove GD&T Advisor from parts?  We used advisor for a little while and had nothing but issues with it and now we have parts out there that have GD&T applied with GD&T advisor and can not fix issues we are having.  Every time we try to open GD&T advisor on these parts we receive a fatal error and are unable to edit any GD&T this is a huge issue any help would be appreciated.
5 REPLIES 5
remy
(To:djacobsma)
very curious.
are you allowed to share a sample model?
djacobsma
6-Contributor
(To:remy)
Unfortunately I can not at this time. I will try to create a dummy part at a later date and upload it as it seems to be a recurring issue with GD&T Advisor.
remy
(To:djacobsma)
Thank you indeed for your effort.
I have an internal information that tells that GDT items must be removed with GD&T Advisor indeed.
but a model would help to judge on evidence.
djacobsma
6-Contributor
(To:remy)
I was able to remove the datums and parameters created by GD&T advisor and then create the new GD&T annotations in CREO on the part to get by now, it causes GD&T advisor to fail if you try to use it, but we have stopped using it for now so it is not a problem other than the "land mine" it creates in that model.
remy
(To:djacobsma)
thank you for your reply.
The issue is more acute than it seems.
I recomment you file a case so that one of our colleague can report it.
