Calculate boolean parameter value by a condition on number
Beniamino71
I have a boolean parameters define on the start part.
The parameter have the default value FALSE
This parameter have to become  TRUE if the number contain '-G' caracters string.
Is it possible use some kind of expression to do so during the generation of part, before the saving?
Many tanks for your aswer
B.
4 REPLIES 4
Seems like you want to set a parameter to be "YES" based upon whether another parameter contains the text "-G". You need a relation.
For example, if
paramName is the string parameter with your "name"
paramBool is the YES/NO (boolean) parameter you want to set
Something like this needs to be in your relations:
paramBool = NO
IF search ( paramName, "-G" ) > 0
  paramBool = YES
ENDIF
Or, perhaps you could use
paramBool = ( search ( paramName, "-G" ) > 0 )
I don't know if the second one will work, but it might.
Beniamino71
(To:KenFarley)
Hi
At the end my right expression is:
GREZZO = NO
IF (search(PRO_MP_CSYS,"-G") > 0)
GREZZO = YES
ENDIF
Your suggestion was very helpfull
Beniamino
please explain exactly what is the meaning of the number contain '-G' characters string.
MH
Martin Hanák
Beniamino71
(To:MartinHanak)
Hi
Number  is the WindChill name of code for the Drawing,  in any case it's ok every parameters that contain for example the file name.
I need that when the file name contaiun "-G " string a specific parameter is set  TRUE
Thnaks for your attention
Beniamino
