Hi, can I install Creo in ARM-based windows? If yes can someone share links for installation help. I am planning to install it in Parallel desktop in Macbook Pro M1 release.
@MartinHanak could you help on this?
@Antonio_Serrano wrote:
anybody know if PTC can be installed in a mac with M1 chip?
Please do not expect that PTC will support M1 chip computers.
I am sorry I do not know the answer to your question. I doubt it is possible.
Parallels should work (at least with the preview for M1 - but it is *not* stable .... yet).
I generally suggest skipping bootcamp... 🙄 (if that ever becomes an option... because .... why?!?)
https://9to5mac.com/2020/12/17/windows-m1-mac-parallels/
https://medium.com/macoclock/how-to-install-windows-10-on-m1-macs-d0f7ff86d268
I too am eager to see how this will all work. 🙂
Dave
I tried but no luck. Setup file does not running..
Ok, but PTC could PTC work in a ARM computer?
I am sorry I do not understand your question. Personally, I see no reason why PTC should support ARM computers.
