Running Creo 2.0 M070.
I have run into this on a fairly regular basis but can't seem to find the common thread connecting the behavior ...
I'll be running along just fine (for hours or even days sometimes) and I go to something that pops open Menu Manager, I try to pick and nothing happens. No action, no confirm, no cancel - nothing. (Funny though, with each click I get a bell in my headphones - bell is off in config.pro)
Sometimes you can get out by selecting a ribon item that doesn't utilize the MM so it closes and you can continue. If however you go back into MM for some reason (any reason) it's still hosed.
Other times you need to click your way out to move on and your stuck, only option is to kill the session.
Somewhere along the way MM gets messed and it just can't right itself.
At one point PTC said it was a because my config.pro was reading a certain option file during startup, I removed it, and the problem persists.
Has anyone seen this, all suggestions are worth a try to me.
Thanks, ScottR.
I thought that bell was an MS programer getting his wings.
In Reply to Bernie Gruman:
Scott,
Are you on Win7?
This sounds a lot like a problem that I had with Win7 and the active window
not pop-ing forward.
The "Bell" your hearing is not the Pro/E Bell, its the Windows warning
bell telling you that you cant click on anything else until you address the
pop-up... Which is hidden, so you can't actually click it. Very
Frustrating!!!
If you do a web search on the subject you will find a couple different
"registry" fixes. One of them should cure your problem.
If you've never done it before, be very careful when messing with your
Registry. (Back it up first) Or, work with your IT department to make
sure it gets done correctly.
Good Luck
Bernie
Bernie Gruman
Owner / Designer / Builder
www.GrumanCreations.com
PTC quality philosophy: We've upped our quality standards. Up yours.
