Can't pick in menu manager
Running Creo 2.0 M070.
I have run into this on a fairly regular basis but can't seem to find the common thread connecting the behavior ...
I'll be running along just fine (for hours or even days sometimes) and I go to something that pops open Menu Manager, I try to pick and nothing happens. No action, no confirm, no cancel - nothing. (Funny though, with each click I get a bell in my headphones - bell is off in config.pro)
Sometimes you can get out by selecting a ribon item that doesn't utilize the MM so it closes and you can continue. If however you go back into MM for some reason (any reason) it's still hosed.
Other times you need to click your way out to move on and your stuck, only option is to kill the session.
Somewhere along the way MM gets messed and it just can't right itself.
At one point PTC said it was a because my config.pro was reading a certain option file during startup, I removed it, and the problem persists.
Has anyone seen this, all suggestions are worth a try to me.
Thanks, ScottR.
