Client Installs of Pro/E
JeffHoracek
2-Explorer
Question for you all,
We're planning on upgrading to WF4 over the next couple of weeks. We've been running WF2 on a network install and at times it is a little slow. After testing WF4 on the network install, it is painfully slow to load. Ideally, I'd like to "push" Pro/E down to each of the client workstations. I'm not sure what the most efficient method is to accomplish this. Can I simply copy the folder structure from the network to the client machines and point the shortcuts to the local install?
What is the best method for handling installing new maintenance releases? I want everyone to be on the same release.
Jeff Horacek
Sr. Designer
[cid:735083218@09112009-1991]
0 REPLIES 0
