CoCreate 17.0 annotation modules crashes
Joan
I have a problem, actually i'm using CoCreate 17.0 and it works perfectly fine until i start annotation modules, then the software crashes and i have to shut it down from task manager. No error message...
With CoCreate 16.50 there is no problem, it only happens with CoCreate 17.0 version. So, i don't know if the softwate wasn't installed properly or what.
For further information i'm using Windows XP.
Thanks in advance.
hemberger
(To:Joan)
Can you provide some information about your graphics card and try the following:
Change the graphic acceleration from hardware to software.
Best would be to open a call with your value added reseller (Arion Data?)
Hans-Georg
