Config Select
Wouter
Config Select
Hello everyone,
Some time ago I made a script to start Pro/ENGINEER at work with the option to be able to select multiple different configurations for each customer and each project.
For example I set it up to be able to choose between running Pro/ENGINEER or Creo stand-alone or connected to Pro/INTRALINK or WindChill. Then choosing the customer environment, the project and the specific configuration, for example an empty configuration or one with mapkeys. The script then copies all the necessary files from a server to the client (if not already present and not modified), sets the correct path to start from and then runs the program. This way I can distribute configuration changes automatically when a user starts the program with the script. It can also overwrite any files the user may have inadvertently changed, guaranteeing that the correct configuration is always used.
We have been using it for several years now and in that time I have extended the functionality to make it a script tool that can be used in any case where files are to be copied before running a program.
I decided to release it to the public in hopes of it being of use to other CAD users. It can be downloaded here: Config Select
If you find it useful or have suggestions or comments, pleas let me know!
Wouter
0 REPLIES 0
