"Willy Chidichimo" wrote:
Add this line to config.pro replacing the path with your specifics: system_colors_file F:\Wildfire 4\_startupWF4\\SYSCOL.SCL Sorry, can't help with CURRENT.PRO.
"Hatim Abdul" wrote:
Put those files in the start-up directory. They will be loaded automatically upon launching the program. Make sure you kepp the exact name of "config.pro" for the *.pro file if you want it to load automatically.
"Xavier Casademunt" wrote:
Hi, you need put the adress of your config file in the correct line of congif.pro See this picture, it's in spanish but i hope that help you.
"David Butz" wrote:
In summary: 1. Add the "system_colors_file ..." line to your config.pro file. 2. You cannot get CURRENT.PRO to load automatically; the system won't recognize that file name for automatic loading. You can get the system to automatically load up to 4 config files: config.sup and config.pro from the text sub-directory of your "load point" and 2 more config.pro files, one each from your startup and home directories. Either rename your file to config.pro or use a mapkey to load CURRENT.PRO. Look at the Help files or recent Forum discussions about config files for more information.
"David Butz" wrote:
In summary: Look at the Help files or recent Forum discussions about config files for more information.
"Kevin Demarco" wrote:
The problem isn't the information you are being given it's that those trying to help can't see what you are doing to determine what the problem is....... If you have placed the config.pro, config.win, and *.scl in that directory you should see them listed.
Rename current_session.pro to config.pro For the config file to be loaded automatically, it must have the name config.pro
