Creo 2.0: Surface cuts - how to use surfaces for cuts only?
I am currently involved in a student project and have developed a model (of a chassis) using a 'top down assembly' style. The square bars (individual parts) have been assembled in place and then cut to length and shape using surface cuts. Cuts are performed by copying surface, solidify > cut. Some surface cuts using surfaces from other parts and also some cuts using surfaces made purely to cut. The surfaces used purely to cut now get in the way of the model and must be hidden each time the model is loaded, they also appear when the model is exported for FEA and therefore we are currently saving the model as a STEP file with solid objects only.
Main question:
Surely there must be a way to have a surface which is only used as a cut and not part of the model? i.e. Can you make a surface to act only as a feature rather than part of the assembly?
Thanks in advance!
Pic: Shows fills/ surfaces (used to cut parts to length) hiding the actual chassis.
