Creo 3.0 , can't edit if object is at a "released" state
kjohns101
In creo 2.0 objects could be edited without check out even when config is set to "dm_checkout_on_the_fly" is set to "continue" waiting for tech support to get back to me, creo 3.0 M020, WC 10.1 M040
llie
(To:kjohns101)
Kevin,
This function does work in Creo 3.0 M020. "dm_checkout_on_fly" set to
"continue." I was able to change a dimension on a file that has a state of
"Released" and modify it locally. It shows "+" in my workspace.
Creo 3.0 M020, PDMLink 10.2 M020
Lance Lie
Sr. Info Sys Technologist II
Global Business Services - Information Technology
Raytheon Company
714-446-2806 (office)
1801 Hughes Way
Fullerton, CA 92833 USA
www.raytheon.com
This message contains information that may be confidential and privileged.
Unless you are the addressee (or authorized to receive mail for the
addressee), you should not use, copy or disclose to anyone this message or
any information contained in this message. If you have received this
message in error, please so advise the sender by reply e-mail and delete
this message. Thank you for your cooperation.
