Creo 3 installs without any reported errors, but will not launch ( M040, Win 7 64 bit). how do I fix it?
Well I found a solution. The desktop icon was set-up by the installation to to run parametric.exe. I changed it to parametric.bat and it works.
Mark,
just a note ...
I am confused by the fact that parametric.exe does not work and parametric.bat does work, because parametric.bat calls parametric.exe ...
Martin Hanak
I dunno. Even thought the psf is in the same directory, maybe parametric.exe needs the location of the PSF
"C:\ptc\Creo 3.0\M040\Parametric\bin\parametric.exe" "C:\ptc\Creo 3.0\M040\Parametric\bin\parametric.psf" %*
Did you use the "start" command and the closed quotes? I.e.:
start "" "<creo_install_dir>\Parametric\bin\parametric.exe"
No. I was just trying using the Icon that setup.exe created
